Hi,everyone!
I'm building base3.14.5 for vxworks-ppc604 on solaris 8 SUN
Workstation with gcc.
However it showed the following error,why?
gmake[3]: Leaving directory
`/export/home/zhaozhuo/gateway/base-3.14.5/src/libCom/O.vxWorks-ppc604' gmake[2]:
Leaving directory
`/export/home/zhaozhuo/gateway/base-3.14.5/src/libCom' gmake -C toolsComm
install gmake[2]: Entering directory
`/export/home/zhaozhuo/gateway/base-3.14.5/src/toolsComm' gmake -C antelope
install gmake[3]: Entering directory
`/export/home/zhaozhuo/gateway/base-3.14.5/src/toolsComm/antelope' gmake -C
O.solaris-sparc-gnu -f ../Makefile TOP=../../../.. T_A=solaris-sparc-gnu
install gmake[4]: Entering directory
`/export/home/zhaozhuo/gateway/base-3.14.5/src/toolsComm/antelope/O.solaris-sparc-gnu' /usr/local//bin/gcc
-c -D_POSIX_C_SOURCE=199506L -D_XOPEN_SOURCE=500
-DOSITHREAD_USE_DEFAULT_STACK -DUNIX
-DSOLARIS=8 -D__EXTENSIONS__ -ansi -O3
-w -D_NO_PROTO -I. -I..
-I../../../../include/os/solaris
../main.c /usr/local//bin/g++ -o antelope
-L/export/home/zhaozhuo/gateway/base-3.14.5/lib/solaris-sparc-gnu/
-R/usr/local//lib -L/usr/local//lib -z ignore -z combreloc -z lazyload
-R/export/home/zhaozhuo/gateway/base-3.14.5/lib/solaris-sparc-gnu
closure.o error.o lalr.o lr0.o main.o mkpar.o output.o reader.o skeleton.o
symtab.o verbose.o warshall.o -lCom
/export/home/zhaozhuo/gateway/base-3.14.5/lib/solaris-sparc-gnu//libCom.so:
undefined reference to
`cerr' /export/home/zhaozhuo/gateway/base-3.14.5/lib/solaris-sparc-gnu//libCom.so:
undefined reference to `logic_error virtual
table' /export/home/zhaozhuo/gateway/base-3.14.5/lib/solaris-sparc-gnu//libCom.so:
undefined reference to `endl(ostream
&)' /export/home/zhaozhuo/gateway/base-3.14.5/lib/solaris-sparc-gnu//libCom.so:
undefined reference to `__out_of_range(char const
*)' /export/home/zhaozhuo/gateway/base-3.14.5/lib/solaris-sparc-gnu//libCom.so:
undefined reference to `ostream::operator<<(char const
undefined reference to `__length_error(char const *)' collect2: ld returned 1
exit status gmake[4]: *** [antelope] Error 1 gmake[4]: Leaving directory
`/export/home/zhaozhuo/gateway/base-3.14.5/src/toolsComm/antelope/O.solaris-sparc-gnu' gmake[3]:
*** [install.solaris-sparc-gnu] Error 2 gmake[3]: Leaving directory
`/export/home/zhaozhuo/gateway/base-3.14.5/src/toolsComm/antelope' gmake[2]:
*** [antelope.install] Error 2 gmake[2]: Leaving directory
`/export/home/zhaozhuo/gateway/base-3.14.5/src/toolsComm' gmake[1]: ***
[toolsComm.install] Error 2 gmake[1]: Leaving directory
`/export/home/zhaozhuo/gateway/base-3.14.5/src' gmake: *** [src.install]
Error 2
- Re: building base3.14.5 Andrew Johnson
RE: I see the light (with epics) Steven Hunt
<2004>
2025
2026
RE: Compiler switches on RISC byte alignment Fairley, Diane
<2004>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
