1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Compiler switches on RISC byte alignment
To: "Lawrence T. Hoff" <[email protected]>
Cc: "Fairley, Diane" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Thu, 02 Sep 2004 15:27:50 -0400
Hi:
I'm surprised Jeff Hill hasn't jumped onto this thread.
He and I had talked about similar issues before.
Maybe he's getting some work done and ignoring tech-talk.
Anyway, the thing about using packed structures
in order to access memory mapped I/O or
raw network packages is that you often run
into compiler-specific "pack" instructions.
Larry's copy works around the alignment,
next you'd run into byte order issues when
you change the CPU type.
The most portable way of coding might be
to always use byte pointers and assemble/disassemble
the data yourself. So instead of
typedef struct __attribute__ ((packed)){
     unsigned char  uCh;
     short          sInt;
you use
  volatile char *buf = <some address>;
  unsigned char uCh = *(buf++);
  unsigned short low = *(buf++);
  unsigned short high = *(buf++);
  short sInt = (high << 8) | low;
You can somewhat beautify this by defining routines
unpack_short(), ...
-Kay
On Sep 2, 2004, at 14:56, Lawrence T. Hoff wrote:
As far as I know, that is a characteristic of the SPARC processor, and cannot be
influenced by compiler directives. You *can* use byte-oriented instructions on
data which is not on "natural" boundaries. I.e. you could access "lInt" as follows
(from a packed array):
unsigned long int temp;
memcpy(&temp, &testdata.lInt, sizeof(temp));
printf("testdata.lInt = %lu", temp)
HTH -- Larry
does not print the right value. A pointer to an unaligned structure member results in a segment violation.
RE: Compiler switches on RISC byte alignment J. Frederick Bartlett
Re: Compiler switches on RISC byte alignment Till Straumann
RE: Compiler switches on RISC byte alignment Fairley, Diane
Re: Compiler switches on RISC byte alignment Lawrence T. Hoff
Prev: Re: Compiler switches on RISC byte alignment Lawrence T. Hoff
Next: RE: Compiler switches on RISC byte alignment Fairley, Diane
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Compiler switches on RISC byte alignment J. Frederick Bartlett
