Yes, you are right, this means "You're wrong." :)
JCA is a set of interfaces allowing to "plug" CA implementation and until recently only JNI implementation exitsts.
We developed a pure java implementation of a CA client called CAJ (Channel Access in Java), which will "plug" into the JCA - this means all the applications will require only 1 line of change (due to current design) to make it work with CAJ. Also CAJ can (and probably will) be included in the next JCA release (2.2).
We expect to release CAJ soon. We want to do some more thorough testing before doing so :)
Till Straumann wrote:
I've not been following JCA development closely, sorry, but I thought
JCA was a 'true' java implementation of a CA client. However, from
peeking
at the on-line document I got the impression that I'd still
need a native CA client library (what is JNI?). Please tell me I'm wrong.
Thanks
-- Till
- JCA 2.1.3 released Rok Sabjan
- Re: JCA 2.1.3 released Till Straumann
Re: Converting GPIB device support from R3.13.9 to R3.14.6 Eric Norum
<2004>
2025
2026
Record Type Doc Benjamin Franksen
<2004>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
