1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: install base 3.14.6 in linux-x86 error
To: [email protected]
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 8 Sep 2004 09:32:02 +0200
If you want to compile base for vxWorks target systems, you will have to
change the VX_DIR entry in ...base.../configure/RELEASE to point to your
vxWorks installation.
(This is also mentioned in the file ...base.../documentation/README.1st
under "Software Requirements / Tornado 2".)
Hope this helps,
Ralph
>>>>> "xuguanglei" == xuguanglei  <[email protected]> writes:
  > hello,all
  > after i follow the steps of documentation
  > i got the error like this
  > gmake[3]: /usr/local/vw/tornado202p1/host/x86-linux/bin/ccppc£ºcommon not
  > find
  > gmake[3]: *** [bucketLib.o] error 127
  > gmake[3]: Leaving directory
  > `/usr/local/epics/base-3.14.6/src/libCom/O.vxWorks-ppc604'
  > gmake[2]: *** [install.vxWorks-ppc604] error 2
  > gmake[2]: Leaving directory `/usr/local/epics/base-3.14.6/src/libCom'
  > gmake[1]: *** [libCom.install] error 2
  > gmake[1]: Leaving directory `/usr/local/epics/base-3.14.6/src'
  > gmake: *** [src.install] error 2
  > does this means i must install cross-gcc-2.9.6.tar.gz?
install base 3.14.6 in linux-x86 error xuguanglei
Prev: install base 3.14.6 in linux-x86 error xuguanglei
Next: Segmentation fault for CA client(EPICS 3.14.6) Song, Jinhu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
