1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ca_repeater bug (was Bugs in 3.14.5)
To: Till Straumann <[email protected]>
Cc: [email protected]
Date: Thu, 16 Sep 2004 10:43:46 -0400
Till Straumann wrote:
> Folks.
> the caRepeater thread calls 'exit()' which is not really
> what you want to do from the ca server (I guess)
> -- T.
Many thanks to Till Straumann for tracking  down this bug.
A while ago, I posted the following message to tech-talk:
> The IOC hung at iocInit() after we tried to add the eighth
> motor controller cards in the crate running RTEMS-mvme2307.
> Further tests showed that,  as a wokaround,one clock tick of delay is
> needed between the end of the scaler_init_record()
> and before it entered the oms_init_record().  At this point, it seems
> that the bug  might not be  even RTEMS related.
> rtems_task_wake_after(0) works fine.
After applying this patch to my  3.14.6 EPICS base,  I do not need the
workaround of one clock tick delay in the  drvOms58.cc motor driver.
Indeed, the bug is not RTEMS related.
Kate
> *** base-3.14.6/src/ca/repeater.cpp.orig        Mon Feb  2 22:32:00 2004
> --- base-3.14.6/src/ca/repeater.cpp     Wed Sep 15 18:31:58 2004
> *** 484,490 ****
>    *  ca_repeater ()
> ! void ca_repeater ()
>       tsFreeList < repeaterClient, 0x20 > freeList;
>       int size;
> --- 484,490 ----
>    *  ca_repeater ()
> ! static int ca_repeater_func ()
>       int size;
> *** 506,512 ****
>           if ( SOCKERRNO == SOCK_EADDRINUSE ) {
>               osiSockRelease ();
>               debugPrintf ( ( "CA Repeater: exiting because a repeater is already running\n" ) );
> !             exit (0);
>           char sockErrBuf[64];
>           epicsSocketConvertErrnoToString (
> --- 506,512 ----
>               osiSockRelease ();
> !             return (0);
> *** 515,521 ****
>               __FILE__, sockErrBuf );
>           osiSockRelease ();
>           delete [] pBuf;
> !         exit(0);
>       debugPrintf ( ( "CA Repeater: Attached and initialized\n" ) );
> --- 515,521 ----
>           osiSockRelease ();
>           delete [] pBuf;
> !         return(0);
> *** 574,579 ****
> --- 574,586 ----
>           fanOut ( from, pMsg, size, freeList );
> +     return -1;
> + void ca_repeater(void)
> +       if ( 0 == ca_repeater_func() )
> +               exit(0);
> *** 582,588 ****
>   extern "C" void caRepeaterThread ( void * /* pDummy */ )
>       taskwdInsert ( epicsThreadGetIdSelf(), NULL, NULL );
> !     ca_repeater ();
> --- 589,596 ----
> !     if ( 0 == ca_repeater_func () )
> !         taskwdRemove( epicsThreadGetIdSelf() );
ca_repeater bug Till Straumann
Prev: RE: compiler base using C++ Builder 6[Scanned] Ralph Lange
Next: GpibCore generates "broken pipe" Eric Williams
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: ca_repeater bug Till Straumann
Next: RE: ca_repeater bug (probably observable only on RTEMS) Jeff Hill
