1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: 3.13 to 3.14 issue
To: "john sinclair" <[email protected]>, "tech talk" <[email protected]>
Date: Fri, 24 Sep 2004 17:00:03 -0500
John,
> Version 3.14 works the same way. However, if this
> auto-include dbd file is present, the sequencer is not visible from
the IOC shell
> (i.e. help did not give seq and typing seq gave an "unknown command"
response).
> Doing a "make clean uninstall install" made no difference. I
> had to eliminate the dbd include file.
I use an auto-include dbd file under 3.14.6 on Linux, with seq
2-0-9beta.  seq works fine, it is defined in iocsh.
The last official release of seq was 2-0-8 I think.  Here are the notes
on 2-0-9:
Version 2.0.9 contains the following changes
seq_connect now initializes assignCount and numMonitoredChans BEFORE
connecting
to the PVs. With the previous versions it was possible to signal that
everything
was connected and the first monitor received before it actually
happened.
So there are no notes about registering seq with iocsh.
What release of 3.14 are you using, and what release of seq?
Mark Rivers
Prev: 3.13 to 3.14 issue john sinclair
Next: explicit dynamic linking and ca.dll . CA bug? Liyu, Andrei
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
