1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Probe bug (enum fields)
To: [email protected]
Date: Mon, 04 Oct 2004 13:48:52 +0200
Hi all,
there is a bug in "probe". Here I have version 1.1.2 (8-2-2002). Can anyone fix it?
The problem appears in the following constellation:
Probe displays a record field of type ENUM (i.e. the VAL-field of mbbi). The value of the field has no corresponding string defined. The modify-window of probe is open.
If the record field is invoked and the modify-window is open or is opened afterwards no problem appears. If the modify-window remains open and the value of the field changes from a defined (with corresponding string) to an undefined (without corresponding string) probe will crash.
Bernd
Prev: RE: portable server Kenneth Evans, Jr.
Next: channel access security document Mark M. Ito
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: portable server Liyu, Andrei
Next: Re: Probe bug (enum fields) Kenneth Evans, Jr.
