1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Not-a-number (nan) issues
To: "'Andrew Johnson'" <[email protected]>
Cc: "'EPICS Tech Talk'" <[email protected]>
Date: Sat, 9 Oct 2004 07:44:20 -0400
	Just to be crystal-clear, it sounds (to me) like the
consensus position is that CA should propagate, communicate,
and otherwise handle NaN (and INF) like any other floating
point value.
	The places where such values should be rejected as
inappropriate are at the client-side ("above" CA), or in
device support. In addition, the aoRecord (but no other
output records) will be modified so that it can optionally
recognize NaN and suppress executing device support "write_ao()"
function when NaN is encountered (essentially as a convenience
for existing device support modules which do not check for NaN
themselves). Is that right?
	Blocking inappropriate values at the client side is not
fool-proof, and not just for NaN. I am sure that the SNS
save/restore program sent NaN due to design or programming error,
not intentionally. Design/programming errors can result in other
inappropriate values to be sent as well (e.g. improperly initialized
memory). NaN, however, has the unique property that it is easily
recognizable as highly likely to be inappropriate. Even so, the
consensus seems to be that suppressing the transmission of NaN via
CA is too restrictive, or may "break" existing applications.
	The ramification of this is that if a NaN (or other
inappropriate value) is sent to a PV, it will make it at least as
far as the record before being flagged as inappropriate. I think
this means that the previous "good" value is obscured. Even though
the NaN is "trapped", it still may be necessary to re-send the
previous value in order for the system to operate properly.
Is that right? In the case of SNS, that would mean using some
older save/restore file that did have an appropriate value for
the PV in question.
Re: Not-a-number (nan) issues Andrew Johnson
Prev: RE: double defenition in Epics Jeff Hill
Next: RE: double defenition in Epics Liyu, Andrei
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Not-a-number (nan) issues Andrew Johnson
Next: Re: Not-a-number (nan) issues Andrew Johnson
