I made a joinArrayRecord - the opposite of a subArrayRecord.
Steve Hunt
On Fri, 2004-10-15 at 00:36, Tim Mooney wrote:
> Dear folks, I'm contributing to a training class on EPICS record types, and
> I'd like to give the students a *complete* list of every EPICS record ever
> written or contemplated. The idea is to convey an accurate sense of how one
> goes about the task of selecting an existing record, or writing a new one,
> to perform a particular task.
> I've compiled the following list from various EPICS web pages, tar files,
> CVS snapshots, etc., and I'm hoping you can help me with any I've missed.
> In particular, if you thought about writing a new record type but didn't,
> or if you know of a record type that's no longer used (e.g., superceded by
> some new capability in base, capability merged into some other record,
> function moved to device support, author got tired of maintaining it, was
> a bad idea from the start, or whatever) your experience might be just the
> thing some new developer needs to be hammered with.
> Anyway, here's the list so far:
> aai array analog input
> aao array analog output
> ai analog input
> ao analog output
> bi binary input
> bo binary output
> calc calculation
> calcout calculation and conditional output
> compress compress
> dfanout data fanout
> eg event-generator (custom hardware)
> egevent event-generator (custom hardware) event
> er event-receiver (custom hardware)
> erevent event-receiver (custom hardware) event
> event event
> fanout sequence of forward links
> histogram bin series of PV values
> longin integer input
> longout integer output
> mbbiDirect multi-bit binary input variant
> mbbi multi-bit binary input
> mbboDirect multi-bit binary output variant
> mbbo multi-bit binary output
> permissive
> sel select a value based on criteria
> seq sequence of reads/delays/writes
> state
> stringin string input
> stringout string output
> subArray get part of an array
> sub subroutine
> waveform array
> asyn Generic interface to asyn port
> scaler Control a bank of counters
> sseq string sequence (cf. seq record) - Execute
> a sequence of EPICS writes to a set of EPICS
> PVs; optionally, wait for completion after
> write.
> epid Enhanced PID record
> timestamp Timestamp record, exports its timestamp as a
> string
> genSub Multi-I/O subroutine, handles arrays
> transform Like 'calcout', but supports 16 expressions
> that can use the results of any previously
> evaluated expressions
> swait mostly superceded by calcout record
> Evaluate a numeric expression; write the
> result to an EPICS PV; optionally wait for
> completion.
> scalcout string-calc-output (cf. calcout record)
> busy database interface to putNotify() - make
> a complex device useable by ca_put_callback()
> scanparm scan parameters for sscan record
> sscan Programmatically set conditions and acquire
> data (cf. scan record)
> table Control a six-degree-of-freedom optical table
> mca Supports multichannel analyzers
> gpib Probes GPIB
> motor Replacement for steppermotor record - also
> supports servo motors; different device and
> driver support; user/dial coordinates;
> backlash takeout; encoders
> dxp XIA dxp custom
> vme Probes VMEbus
> camac Probes CAMAC
> abDcm Allen Bradley
> ab1771IX Allen Bradley
> ab1771IFE Allen Bradley
> ab1771N Allen Bradley
> ab1791 Allen Bradley
> cad Implements Gemini Command/Action Layer
> car between IOC's
> sir
> apply
> hiv Access LeCroy or CAEN HV mainframes
> interp General-purpose interpolation
> pal Emulates PAL-type IC
> serial Probes Serial
> pulseCounter Mizar
> pulseDelay Mizar
> pulseTrain Mizar
> timer Mizar
> spectrum spectrum-analyzer
> waveAnl waveform analysis
> vacScan Spectra VacScan RGA
> archive store the values of a PV for use by an EPICS
> archiving client
> wait early version of calcout
> cpid CEBAF PID record
- list of *all* EPICS records Tim Mooney
RE: list of *all* EPICS records Hammonds, John P.
Re: list of *all* EPICS records Mohan Ramanathan
<2004>
2025
2026
Re: list of *all* EPICS records Brian McAllister
Re: list of *all* EPICS records Noboru Yamamoto
<2004>
2025
2026
