1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VME Address Modifiers in mv2400
To: Nick Rees <[email protected]>
Cc: [email protected]
Date: Fri, 15 Oct 2004 11:41:22 -0500
Hello Nick,
I don't have the mvme2400 distribution; but for the mvme2100 and mvme5100
the $WIND_BASE/target/config/mv[2100/2400/5100].h files have to be modified
and the BSP's rebuilt in order to change the VME AM's.
Using the mv5100.h file as an example, the default VME AM's
are set to non-privileged access through the VAL_LSI[0/1/2/3]_CTL
definitions in mv5100.h.  To change the VME AM from non-privileged to
supervisory change LSI_CTL_USR to LSI_CTL_SUP in the
VAL_LSI[0/1/2/3]_CTL definitions.
Hope this helps,
Ron Sluiter
Nick Rees wrote:
I just had a problem swapping a system from a Heurikon board to a PPC
mvme2400.
It turned out that I had a VME board (VMIC4514) that responded to either
supervisory or user A16 I/O, but couldn't be set to respond to both. It
was set to respond to supervisory mode I/O because that is what I thought
all VxWorks BSP's used. However, this worked with the Heurikon board, but didn't work with the PPC.
Has anyone seen this before. Does anyone have a hint as to the bit of the Motorola BSP I have to change to make it use supervisory VME access?
I apologise that this is really a VxWorks question, but I often find the
tech-talk list a lower bandwith option with equally good results.
Cheers,
Nick Rees
Head of Software and Computing Services
Joint Astronomy Centre Ph: +1 (808) 961-3756
660 N. Aohoku Place Fax: +1 (808) 961-6516
Hilo, HI. 96720 Email: [email protected]
VME Address Modifiers in mv2400 Nick Rees
Prev: Re: list of *all* EPICS records Till Straumann
Next: Re: list of *all* EPICS records Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: VME Address Modifiers in mv2400 Nick Rees
Next: list of *all* EPICS records Tim Mooney
