1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: list of *all* EPICS records -- summary (long)
To: Tim Mooney <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Tue, 19 Oct 2004 13:31:51 +0900
Thank you very much for the comprehensive list of EPICS records.
When I reported records used in KEK, forgot to add one more recrod.
That is called a compact subarray record.
A subarray record copies entire waveform from its input record whenever it is processed.
It means each subarray reocrds will have a buffer to keep an input waveform.
A compact subarry record, however, requires small buffer which is large enough to keep a output waveform,
which is usually much smaller than the input waveform.
Unfortunately, you need to add a new database access routine in base.
(Yes, we in KEK uses a modfied version of EPICS base.)
Noboru
RE: list of *all* EPICS records Allison, Stephanie
Re: list of *all* EPICS records -- summary (long) Tim Mooney
Prev: Re: list of *all* EPICS records -- summary (long) Tim Mooney
Next: Re: list of *all* EPICS records Siddons, David
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: list of *all* EPICS records Kevin Tsubota
