Jeff I was taught to supply inline versions of these functionz when they
are private.
private: // Don't allow:
void * operator new ( size_t ){};
void operator delete ( void * ){};
The compiler will issue the proper error at compile time and since the
code is never used it won't get compiled.
-----Original Message-----
Sent: Thursday, October 21, 2004 11:32 AM
To: 'geyang'; 'tech-talk'
Subject: RE: linking iocCore lib error
> Undefined external symbol
> "cacChannel::operator new(unsigned long)" referenced in "dbChannelIO"
As Till mentioned, that operator is declared, but not defined. It is a
common technique with C++ to declare operators that have compiler
generated
default implementations private if one desires to prevent (at link time)
these compiler generated defaults from being inadvertently used. This
particular situation is clearly creating problems with your compiler,
and
its usefulness isn't entirely clear.
Therefore I will remove the private declarations for the following
operators
from class cacChannel in file cacIO.h for the next release of R3.14.
void * operator new ( size_t );
void operator delete ( void * );
Jeff
> From: geyang [mailto:[email protected]]
> Sent: Sunday, October 17, 2004 5:42 AM
> To: tech-talk
> Subject: linking iocCore lib error
> Hi,everyone:
> I am working to port iocCore to itron, base version is 3.14.4,
compiler
> is SHC(Super Hitachi Compiler). I compiled the itron-sh4 as target and
> got all the iocCore lib files, but when I try to link them, the linker
> has the error as follows:
> Phase OptLinker starting
> L2310 (E) Undefined external symbol "cacChannel::operator new(unsigned
> Optimizing Linkage Editor Abort
> Phase OptLinker finished
> Can anybody give me some advice?
> thank you
> Best regards,
> Geyang
[Fwd: JCA 2.1.4 and CAJ released!] Gasper Pajor
OSI connectWithTimeout Peng, Sheng
<2004>
2025
2026
RE: linking iocCore lib error Jeff Hill
Error Iris Allard
<2004>
2025
2026
