1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asynDriver, devEpics user parameter access
To: "Geoff Savage" <[email protected]>, "EPICS Tech-Talk" <[email protected]>
Date: Wed, 3 Nov 2004 07:41:38 -0600
Hi Geoff,
> How do I access the user parameters at the end of the INP or OUT
string
> allowed in devEpics in my driver?
To expand Marty's answer for release 3-3:
- Driver must implement the asynDrvUser interface
- Device support calls pasynDriver->create() with the user parameter
string
- Driver puts information in pasynUser->drvUser, which is a void *.
Note that the contents of void *drvUser is only understood by the
driver, and sometimes by device support.
In the next release (3-4 or 4-1), we added a new int field,
pasynUser->reason.  If the user parameter just translates to an enum or
int, then in drvUser->create() the driver should use pasynUser->reason,
rather than pasynUser->drvUser.  pasynUser->reason used by the interrupt
support in the new Base interfaces for each of the standard interfaces
(asynInt32, asynUInt32Digital, etc.).
Prev: Re: asynDriver, devEpics user parameter access Marty Kraimer
Next: Re: Channel Access Protocol Specification Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: async driver john sinclair
