1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: async driver
To: john sinclair <[email protected]>
Cc: tech talk <[email protected]>
Date: Thu, 04 Nov 2004 06:06:23 -0600
I did run a test to see if I could successfully reboot an E5810.
Perhaps I did not have enough active gpib activity to cause the crashes you are seeing.
Before the next release I will a harder test.
I do expect the errors you are seeing but It should recover and reconnect when the E5810 is again alive.
that segmentation fault or Illegal Instruction should not happen.
Marty
john sinclair wrote:
Configuration:
linux x86, fedora core-2 with 2.6 kernel
EPICS 3.14.6
Async Driver 3-3
Device is E5810A ethernet - GPIB
The gpibCmd is
{&DSET_AI,GPIBREAD,IB_Q_LOW,"send","%lf",0,132,NULL,0,0,NULL,NULL,0}
Rebooting the E5810A while the ioc is running results in the following:
2004/11/03 17:08:17.480 L0 vxi11 clientCall errno 0 clnt_stat 5
L0 vxiWriteAddressed _? error : RPC: Timed out
2004/11/03 17:08:17.480 mirf:gig600Reading write status "L0 RPC failed
" requested 5 but sent 135129288 bytes
2004/11/03 17:08:17.480 mirf:gig600Reading error.
2004/11/03 17:08:17.480 mirf:gig600Reading lenmsg 5 but nchars written 135129288
2004/11/03 17:08:19.480 mirf:gig600Reading queueRequest failed timeWindow active
2004/11/03 17:08:28.500 L0 vxi11 clientIoCall errno 0 clnt_stat 5
2004/11/03 17:08:28.991 L0 vxi11 clientCall errno 104 clnt_stat 4
2004/11/03 17:08:28.991 L0 vxiDestroyDevLink RPC error : RPC: Unable to send; errno = Broken pipe
2004/11/03 17:08:28.991 L0 vxiDisconnectPort : RPC: Unable to send; errno = Broken pipe
2004/11/03 17:08:31.000 L0 vxiDestroyDevLink RPC error : RPC: Unable to send; errno = Broken pipe
Segmentation fault
Another failure gave these messages:
2004/11/03 17:16:02.500 L0 vxi11 clientCall errno 0 clnt_stat 5
2004/11/03 17:16:02.500 mirf:gig600Reading write status "L0 RPC failed
2004/11/03 17:16:02.500 mirf:gig600Reading error.
2004/11/03 17:16:02.500 mirf:gig600Reading lenmsg 5 but nchars written 135129288
2004/11/03 17:16:04.500 mirf:gig600Reading queueRequest failed timeWindow active
2004/11/03 17:16:13.520 L0 vxi11 clientIoCall errno 0 clnt_stat 5
2004/11/03 17:16:15.871 L0 vxi11 clientCall errno 104 clnt_stat 4
2004/11/03 17:16:15.871 L0 vxiDestroyDevLink RPC error : RPC: Unable to send; errno = Broken pipe
2004/11/03 17:16:15.871 L0 vxiDisconnectPort : RPC: Unable to send; errno = Broken pipe
2004/11/03 17:16:17.880 L0 vxiDestroyDevLink RPC error : RPC: Unable to send; errno = Broken pipe
Illegal instruction
For 10 reboots, the ioc reconnected 7 times and crashed 3 times
async driver john sinclair
Prev: Reminder: EPICS meeting in ASIA, December 2004. registration Noboru Yamamoto
Next: asynInt32SyncIO readOnce Geoff Savage
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: async driver john sinclair
Next: Reminder: EPICS meeting in ASIA, December 2004. registration Noboru Yamamoto
