1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem restoring some PVs with burtwb
To: tech-talk Mailing List <[email protected]>
Date: Thu, 4 Nov 2004 14:49:27 +0100
I have a set of ao-records which I want to write to with burtwb.
These records use the device support CAEN_IO for CAEN SY527 HV modules.
I can set the values via medm or ca_test.
When I use burtwb the values are not touched at all. The burtwb logfile
indicates all is well, connected to all channels, all values written.
I enabled the process printout on one of these records, it gives 1 message
when I change the PV with medm, it gives 7 (why?) messages when used
with ca_test and NONE with burtwb.
burtrb can read the values without any problem.
There is no access security problem, no network problem.
Other ao-records with different device support do work with burtwb.
EPICS base is 3.13..0, burt version?? from Aug 2002
Any clue how to debug this?
Burkhard Kolb
HADES @ GSI Darmstadt
Prev: RE: asynInt32SyncIO readOnce Mark Rivers
Next: Re: Channel Access Protocol Specification Klemen Zagar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: asyn3-3 external access Geoff Savage
