1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Has Anyone Built CMLog with Recent Releases (R3.14.x) of EPICS?
To: "Allison, Stephanie" <[email protected]>, "Munro Jr, John K." <[email protected]>, [email protected]
Date: Tue, 16 Nov 2004 17:32:04 -0500
From: Allison, Stephanie [mailto:[email protected]]
Sent: Tue 11/16/2004 5:17 PM
To: Munro Jr, John K.; [email protected]
Hi John,
>       Has anyone built CMLog (esp. to work with the EPICS alarm handler) with
> recent releases (R3.14.x) of EPICS?  I am interested in using CMLog with R3.14.6.
The CMLOG server and browser are independent of EPICS version.  The CMLOG client and client daemon which run on the IOC are also independent of EPICS but RTEMS is not supported.  So if you have RTEMS IOCs, you'll need to add ifdefs for RTEMS or convert the cmlog client and daemon to use the EPICS OSI utilities.  The only thing that is dependent on EPICS is the hook into the IOC errlog task (an errlog "listener").  We are currently developing such a listener that will use EPICS OSI utilities and will add it to the EPICS soft support list ("iocCmlog") when finished.  Eventually, we'll change CMLOG to build for RTEMS too but no time soon.
Where do you recommend to get the current client distribution?  We would like to use the client side with the Alarm Handler.
Stephanie Allison
Prev: RE: Has Anyone Built CMLog with Recent Releases (R3.14.x) of EPICS? Allison, Stephanie
Next: RE: Has Anyone Built CMLog with Recent Releases (R3.14.x) of EPICS? Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
