Mark,
You are probably accessing VI's that someone saved from
LabVIEW 7. Those VI's will probably work with 6.x, but
someone that has LabVIEW 7 will need to open the VI's and
then do a Save_With_Options to save a version that is
compatible with LabVIEW 6.
Now, to find a volunteer...
-ps
----- Original Message -----
To: <[email protected]>
Sent: Friday, December 03, 2004 12:51 AM
Subject: Labview Shared Memory Interface
Hi all,
Im looking at the shared memory interface between labview
and EPICS. It
seems that I require Labview 7.1 to get the VI files to
run. Can anybody
verify if this is correct ?
Many thanks,
Mark Clift
Control Systems Engineer
Australian Synchrotron Project
Level 17 Nauru House, 80 Collins Street Melbourne
www.synchrotron.vic.gov.au
Any personal or sensitive information contained in this
email and
attachments must be handled in accordance with the
Victorian Information
Privacy Act 2000, the Health Records Act 2001 or the
Privacy Act 1988
(Commonwealth), as applicable.
This email, including all attachments, is confidential.
If you are not the
intended recipient, you must not disclose, distribute,
copy or use the
information contained in this email or attachments. Any
confidentiality or
privilege is not waived or lost because this email has
been sent to you in
error. If you have received it in error, please let us
know by reply
email, delete it from your system and destroy any copies.
- Labview Shared Memory Interface Mark . Clift
RE: Labview Shared Memory Interface Liyu, Andrei
channel access errors Geoff Savage
<2004>
2025
2026
<2004>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
