Well. I certainly didn't expect that my seemingly simple question would
stimulate such long and interesting replies. I guess I was expecting that
there would be a simple answer, but it seems that that is not to be.
Maybe I'll try and rephrase my question.
I am interested in knowing what techniques other people in other facilities
use to initialise the values of their output records so that they match the
state of the equipment when the IOC is rebooted. It seems to me that this
is necessary in order to ensure that the widgets of OPIs (such as EDM) are
correctly set after the IOC has initialised.
Steve Banks
Australian Synchrotron Project
Department of Infrastructure
Level 17, 80 Collins Street
Melbourne VIC 3000
tel: +613 9655 6303
fax: +613 9655 8666
web: www.synchrotron.vic.gov.au
Russell Redman
<russell.redman@nrc- To: Ralph Lange <[email protected]>, Mark Rivers <[email protected]>
cnrc.gc.ca> cc: <[email protected]>, <[email protected]>
Subject: Re: Initial value readback from hardware into output records
10/12/04 06:20 AM
This is a difficult problem, no two ways about it. I have fairly regularly
thought that initialization was one of the weaker aspects of EPICS. There
are also some really nasty differences between hardware and simulation mode
I/O that need to be considered.
Mark Rivers has pointed out that my existing database does not use drivers
based on the generic asynDriver interface, and does not need to be changed
to use them. Notwithstanding, there do appear to be some real advantages
to using the new drivers and the database should probably be rewritten to
use them if and when it gets ported to 3.14.
Most of the control variables that I have to work with are not controlled
directly by the IOC. We have a large set of peripheral controllers that are
connected by CAN bus and serial lines to the IOC. Thankfully, we were able
to avoid GPIB, but many of the same issues arise for all three media. My
impression is that the existing CAN bus drivers do not use asynDriver, but
the warm reboot option seems sufficiently appealing that âweâ (i.e. not me
right now) might want to rewrite the CAN drivers to use a similar
interface.
Mark also suggested that a solution might be to write an asyn simulation
driver that looks like a real driver but does not attempt to access the
hardware. I am VERY reluctant to attempt this solution, partly because it
sounds like a lot of work, but mostly because it ignores completely the
SIMM and SIML fields that should really be used to control simulation mode.
Instead, we would have to boot the whole database in either hardware or
simulation mode and it would be impossible to switch between them
on-the-fly. I prefer Ralphâs implied approach of understanding, and
possibly correcting, the way records manage the SIML field during iocInit.
I fear it is impractical to detect the presence or absence of hardware when
it sits on the other end of a cable. All our serial connections, for
example, are connected to a terminal server. The terminal server itself
does not detect whether there is a cable attached to a port, much less
whether the cable is plugged in at the other end and the peripheral
controller is turned on. The only test available is to read a value back
from the hardware and wait to see whether the reply times out. This test
would have to be completed for each serial line before any dependent
records could complete their initialization, and I do not see any generic
way to do it.
In simulation mode, the record should still read back its initial value
during init_record, but from the simulator instead of from the hardware.
Whatever the hardware does, the simulator should do too, although it may
use a very different mechanism. Note that this immediately raises very
serious issues about the order in which records are initialized, which I
will come back to below.
The correct solution might be to allow allow records to be initialized
during operation and to do this every time SIMM changes. This would allow
the operator to switch a module in and out of simulation mode safely and
repeatedly. I am not sure what the side effects might be however, beyond
the obvious problem that the value of the record is likely to change
unpredictably during the switch between modes, and that different records
will change their modes and their values at different times. In operation,
I would start the database by default in simulation modem, to avoid
accessing possibly nonexistent hardware, and would then switch the mode to
hardware by hand (and possibly separately for each hardware package) or by
setting a record in the startup script.
Note that this is not the same as creating and deleting records
dynamically, although dynamic records could probably be used to address the
problem.
The order and timing in which records are initialized is a difficult
problem that has given me a lot of grief. I have been assuming that a
record that reads back a value during iocInit will not process, and will
not cause other records linked to it through FLNK, CPP INLINKs or monitors
to process. Otherwise, mayhem would result as records attempt to process
before they have been initialized. I suspect I am missing something here
because I have not read through the code. If I recall correctly, iocInit
runs in two passes. The first sets up all the data structures and device
support, and the second process all those records that have PINI=YES. It
sounds like the value is being read back during the initialization of the
device support. Surely, the correct time to read a value back from
hardware is during the second pass. By this point it should be OK for the
record to process, and for it to cause any linked records or monitors to be
processed as well.
Some related issues: If the normal asynchronous callback is used to fetch
the value from the hardware, would that cause the record to process? What
happens if the hardware sends back its reply before the database has
completed iocInit? Would data be lost? Many peripherals do not use flow
control and will continue to ram bytes into a port regardless of whether
the IOC is listening. A really thorny problem arises for output records
whose values are read back from the hardware in groups. Status words are
often of this kind, and I have several examples in my IOC of CAN messages
that return four real values as 12-bit integers for the last-set values of
a collection of DACs. This is hard enough to deal with using ai records in
âI/O Intrâ mode, where the logic in simulation mode is utterly, utterly
different from what happens in hardware mode. It will be much worse for ao
records during iocInit, which will not be configures for SCAN=âI/O Intrâ..
I do not have a solution for this, except to disable the
read-during-initialization for such records.
Setting global values is also a bit tricky. You cannot use dbpf until
after iocInit, by which time it is too late to set the simulation mode or
initialization policy. Default starting values can be set hard-coded into
the database, or configured using templates in the startup script. I
suspect that templates are the correct tool, although I have not yet had
any reason to try them in my own database.
Enough musing for now. I have probably confused everyone who bothers to
read this far. I know my own head is spinning.
Cheers,
Dr. Russell O. Redman
Tel: (250) 363-6917 | Fax: (250) 363-0045
<mailto:[email protected]>
National Research Council Canada | Conseil national de recherches Canada
5071 West Saanich Road | 5071 West Saanich Road
Victoria, B. C. V9E 2E7 | Victoria, C.-B. V9E 2E7
Government of Canada | Gouvernement du Canada
On 2004-12-09 3:39 AM, "Ralph Lange" <[email protected]> wrote:
Interesting ...
Looking at the ao record I realized:
While the record support's process() usually checks for the
simulation
mode by reading the SIML link and only calls device support in "real
mode", its init_record() only sets SIMM if SIML is a constant and
calls
device support anyway.
For a record coming up in simulation mode after a reboot, whatever
you
do seems to be wrong:
- If you skip device support's initialization, the record cannot be
switched to real mode later, as the device is not initialized.
- If you do the initialization, you will access hardware, which
might
be against the intention for rebooting the record in simulation
mode
in the first place.
It looks as if a proper solution will not be available before EPICS
is
capable of adding records on-line - then there have to be ways for
late
hardware initialization, which can also be used for this case.
For the time being ...
Here's an idea to make a database work more smoothly without the
hardware being present:
In its init routine, the device support should be able to detect if
the
hardware is missing. Instead of raising an error and maybe blocking
the
record (e.g. done by setting PACT=1) it could internally mark the
hardware as missing and force the record into simulation mode
instead.
If your database doesn't use the simulation mode mechanism or has
been
set up to come up in simulation mode, everything will be just fine.
What if the record later gets switched to real mode (or gets this
from
its SIML location)? Check for the missing hardware flag in the device
support's write routine and raise an error (set the record INVALID).
The
overhead for this additional check (done at every processing) should
be
tolerable.
Zero-tolerance mode: On production systems (where the hardware should
please really exist) device support should still raise errors and
maybe
block the record at boot time. So you might want to add a common
global
switch (variable to be set from the startup script) for all your
device
supports to enable the fault tolerant procedure (disabled by
default).
What do you think? Doesn't really look perfectly elegant, I agree.
Should the case of "missing hardware at boot time" be handled in a
more
generic way? (I.e.: what would a future device support interface need
to
handle this properly?)
Cheers,
Ralph
>>>>> "Mark" == Mark Rivers <[email protected]> writes:
> Russell,
> The features I was discussing only apply to generic device
support for
> drivers that use the new asynDriver interfaces. Since your
drivers are
> not based on asyn, and you are not using the asyn generic device
> support, then this will not be a problem for you. Nothing in
EPICS base
> has changed in this regard.
> If you begin to use asyn-based drivers, and you don't want the
records
> to set the value during init_record you can:
> - Use non-generic device support
> - Write an asyn SIMULATION driver, that looks just like the real
driver,
> but does not talk to hardware
> Mark
> -----Original Message-----
> From: Russell Redman [mailto:[email protected]]
> Sent: Tuesday, December 07, 2004 10:44 AM
> To: Mark Rivers; [email protected];
> [email protected]
> records
> I am curious about a closely related issue that I fear will
> arise when we try to upgrade our version of EPICS from 3.13.8 to
use
> the newer software. My code runs in both hardware and simulation
modes
> to allow the software to be tested without having the hardware
attached.
> When the IOC boots, it does not know which mode it is supposed to
be in.
> The operator sets HARDWARE/SIMULATION mode flag, then runs an
INITIALISE
> action to open communications with hardware or with the
simulator, as
> appropriate. Very bad things happen if the EPICS drivers attempt
to
> read back values from nonexistent hardware, and I have put a
> considerable effort into the startup code to ensure that I/O
records do
> not process on startup.
> So here is my question: How can I PREVENT an output record
from
> reading back a value during init_record from hardware that may or
may
> not exist?
> Cheers,
Any personal or sensitive information contained in this email and
attachments must be handled in accordance with the Victorian Information
Privacy Act 2000, the Health Records Act 2001 or the Privacy Act 1988
(Commonwealth), as applicable.
This email, including all attachments, is confidential. If you are not the
intended recipient, you must not disclose, distribute, copy or use the
information contained in this email or attachments. Any confidentiality or
privilege is not waived or lost because this email has been sent to you in
error. If you have received it in error, please let us know by reply
email, delete it from your system and destroy any copies.
- Re: Initial value readback from hardware into output records Russell Redman
Re: EPICS meeting in ASIA, Dec.8-10,2004 : Web page update Kazuro FURUKAWA
<2004>
2025
2026
Re: Initial value readback from hardware into output records Benjamin Franksen
<2004>
2025
2026
