A while ago, Kate Feng wrote :
>The drvIK320.c for the Heidenhain IK320 encoder posted in
> the http://www.aps.anl.gov/aod/bcda/synApps/index.php
> required the counting semaphore.
Many thanks to people who made suggestions offline
regarding the counting semaphore. Now, the driver for IK320
encoder is ported to our RTEMS application. The original author
of the IK320 encoder wrote:
>The counting semaphore keeps track of outstanding
>jobs on the IK320 card, letting the IOC wait for the last
>axis on the IK to finish.
Since we have hardware setup for only one axis, we think it's
safe to use the counting semaphore for outstanding jobs
in case of multiple axes. I did not find official document
regarding the implementation of the counting semaphore.
To make life easier, I follow the document of vxWorks and
RTEMS and the source code of EPICS. To one's
consideration/reference, attached at the end is the
implementation of the counting semaphore I tested for the IK320
encoders. It is almost identical to the code of RTEMS/osdEvent.c
except for that the "RTEMS_SIMPLE_BINARY_SEMAPHORE"
is replaced by "RTEMS_COUNTING_SEMAPHORE".
Perhaps, to one's interest, I listed the various suggestions I got
for the usage of the counting semaphore for the IK320 encoder.
1. the counting semaphore could be replaced by the binary
semaphore (e.g. epicsEvent) .
2. the counting semaphore could be replaced by the
message semaphore (e.g. epicsMessage).
3. the counting semaphore is a nice primitive to be implemented.
Thanks again,
Kate
* Create a counting semaphore
rtems_id epicsCountCreate(int initialState)
rtems_status_code sc;
rtems_id sid;
rtems_interrupt_level level;
static char c1 = 'a';
static char c2 = 'a';
static char c3 = 'a';
sc = rtems_semaphore_create (rtems_build_name ('B', c3, c2, c1),
initialState,
RTEMS_FIFO | RTEMS_COUNTING_SEMAPHORE |
RTEMS_NO_INHERIT_PRIORITY | RTEMS_NO_PRIORITY_CEILING |
RTEMS_LOCAL,
0,
&sid);
if (sc != RTEMS_SUCCESSFUL) {
errlogPrintf ("Can't create binary semaphore: %s\n",
rtems_status_text (sc));
return 0;
rtems_interrupt_disable (level);
if (c1 == 'z') {
if (c2 == 'z') {
if (c3 == 'z') {
c3 = 'a';
else {
c3++;
c2 = 'a';
else {
c2++;
c1 = 'a';
else {
c1++;
rtems_interrupt_enable (level);
return sid;
void epicsCountDestroy(rtems_id id)
sc = rtems_semaphore_delete(id);
printf("Can't destroy semaphore: %s\n", rtems_status_text (sc));
void
epicsCountSignal(rtems_id id)
sc = rtems_semaphore_release (id);
printf("Can't release semaphore: %s\n", rtems_status_text (sc));
int epicsCountWait(rtems_id id)
sc = rtems_semaphore_obtain (id, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
return ERROR;
return OK;
int epicsCountWaitWithTimeout(rtems_id id, double timeOut)
rtems_unsigned32 wait;
rtems_interval delay;
extern double rtemsTicksPerSecond_double;
if (timeOut <= 0.0) {
wait = RTEMS_NO_WAIT;
delay = 0;
else {
wait = RTEMS_WAIT;
delay = timeOut * rtemsTicksPerSecond_double;
if (delay == 0)
delay++;
sc = rtems_semaphore_obtain (id, wait, delay);
if (sc == RTEMS_SUCCESSFUL)
return 0;
else if (sc == RTEMS_TIMEOUT)
return -2;
else
return -1;
CA links and EPICS Records user routines Andy Foster
MSVCPRT.LIB bharoto
<2005>
2025
2026
Re: CA links and EPICS Records user routines Ralph Lange
MSVCPRT.LIB bharoto
<2005>
2025
2026
