1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: if-then-else in iocsh
To: [email protected], Emmanuel Mayssat <[email protected]>
Date: Fri, 28 Jan 2005 10:08:08 -0800
Hello,
I would like to check for the settings of an environment variable in
iocsh. If the envrionment variable is not set, then I want to set it to
a default value.
Is there any way to do that ?
Emmanuel Mayssat
Lyncean Technologies, Inc.
Direct: 650/320-8300 x409
Cell: 650/793-0626
Re: if-then-else in iocsh Andrew Johnson
Prev: Re: write access through ca gateway Kenneth Evans, Jr.
Next: Re: if-then-else in iocsh Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
