1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Yet another VxWorks MBUF issue...
To: <[email protected]>
Date: Fri, 28 Jan 2005 21:37:02 -0500
	This issue is not specific to EPICS, we noticed it in a
non-EPICS VxWorks system at RHIC. However, since EPICS is
commonly run on VxWorks, this problem could show up on an
EPICS system. I mention this just in case someone in the
community has run into it........
	The problem is a bug in the NFS client software in
VxWorks. The S/W does not gracefully handle the case when
"user" MBUFS have been depleted, but "system" MBUFs have
not. Under these circumstances, it is possible to create
a socket, but may not be possible to bind that socket to
a local port. This causes the NFS client S/W to get confused,
and neglect to close the socket. The socket (and its
associated file descriptor) are forever orphaned (until a
reboot).
	The situation at RHIC where this occurred was a system
which provided data to a user display related to superconducting
magnet quench detection, and optionally stored "trend" data
directly on a (Windows NT) file server via NFS. Under certain
circumstances (enough simultaneous operator displays combined
with a network interruption), MBUFS could temporarily become
depleted. Normally this was no big deal. After the network
interruption was corrected, the MBUFs were freed. However, if
the data logging was enabled during that time, each attempted
NFS operation resulted in one "leaked" socket and file descriptor.
In extreme cases, all 256 file descriptors were leaked, the
system required a reboot and the trend data was lost.
	I was able to substitute a "fixed" clnt_udp.c module,
based on the source code provided in the "unsupported"
directory, which cures this problem. I am currently working
with WRS on incorporating this fix in future releases of
VxWorks. In the meanwhile, if anyone needs a fixed NFS client,
contact me, and I can send the source code.
	A clear signature that this has happened on a VxWorks
system is one or more UDP sockets which are not bound to
any address. These can be seen via inetstatShow:
f02624   UDP        0      0  0.0.0.0.0             0.0.0.0.0
f02498   UDP        0      0  0.0.0.0.0             0.0.0.0.0
HTH -- Larry
Prev: Re: if-then-else in iocsh Emmanuel Mayssat
Next: EDM and Text Control Gavin Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: mbbo strings linked to mbbo commands Emmanuel Mayssat
