1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: DeltaTau PCI Motor Control Boards and Linux
To: <[email protected]>, <[email protected]>
Date: Tue, 1 Feb 2005 09:54:00 -0000
Hi Wayne,
I'm not sure if anyone has developed device support for PCI Delta Tau.
However, at Diamond we are using the Turbo PMAC2-VME Ultralite, using
standard VME crates and EPICS 3.13.9. Ron Sluiter (from APS) wrote the
device and driver support for the motor record  - which is our primary
interface to the PMAC. We are also going to be using binary in/out and
analogue in/out to communicate additional information to the PMAC for
complex motions.
Dr Martin Norbury
Software Engineer Beamline Systems
Diamond Light Source Ltd.
Rutherford Appleton Laboratory
Chilton, Didcot.
Oxon
OX11 0QX
Tel: 44 (0) 1235 778235
Email: [email protected]
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]]
> Sent: 01 February 2005 05:51
> To: [email protected]
> Subject: DeltaTau PCI Motor Control Boards and Linux
> Hi,
> We are looking at using the PCI version of the Delta Tau
> motor control boards on the beamlines at the Australian
> Synchrotron Project. The likely board at this stage is the
> Turbo PMAC2 Ultralite PCI. Our standard IOCs are Linux based
> PCs, running EPICS 3.14.6.
> I was wondering if anyone has done any work on developing
> EPICS device support for any of the PCI Delta Tau boards under Linux?
> Thanks,
> Wayne Lewis
> Australian Synchrotron Project
> Department of Infrastructure
> Level 17, 80 Collins Street
> Melbourne   VIC   3000
> tel:  +613 9665 9561
> fax:  +613 9655 8666
> web: www.synchrotron.vic.gov.au
> Any personal or sensitive information contained in this email
> and attachments must be handled in accordance with the
> Victorian Information Privacy Act 2000, the Health Records
> Act 2001 or the Privacy Act 1988 (Commonwealth), as applicable.
> This email, including all attachments, is confidential.  If
> you are not the intended recipient, you must not disclose,
> distribute, copy or use the information contained in this
> email or attachments.  Any confidentiality or privilege is
> not waived or lost because this email has been sent to you in
> error.  If you have received it in error, please let us know
> by reply email, delete it from your system and destroy any copies.
Re: DeltaTau PCI Motor Control Boards and Linux Zhijian Yin (ZY)
Prev: Re: EDM and Text Control Ralph Lange
Next: Initial STAT and SEVR for soft ai and ao records Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: DeltaTau PCI Motor Control Boards and Linux Wayne . K . Lewis
Next: Re: DeltaTau PCI Motor Control Boards and Linux Zhijian Yin (ZY)
