1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Initial STAT and SEVR for soft ai and ao records
To: "Marty Kraimer" <[email protected]>
Cc: <[email protected]>
Date: Tue, 1 Feb 2005 15:09:52 -0600
Marty,
Yes this is the expected behavior. The idea is that SEVR is always
invalid and STAT is always UDF until the record is processed the first
time.
For soft device support with a constant input link this does not make sense to me.  Let's say I want an ai record to simply hold the value of Pi which I will use in other records.  If those other records fetch the link with MS then they will also be Invalid.  Why is such a soft record Invalid if it has never processed? Such records should never need to process.   If UDF=0 it seems illogical that STAT=UDF.
Prev: Re: Initial STAT and SEVR for soft ai and ao records Marty Kraimer
Next: Re: Initial STAT and SEVR for soft ai and ao records Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Initial STAT and SEVR for soft ai and ao records Bernhard Kuner
Next: RE: Initial STAT and SEVR for soft ai and ao records Mark Rivers
