1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: DeltaTau PCI Motor Control Boards and Linux
To: "EPICS" <[email protected]>
Date: Fri, 4 Feb 2005 16:54:38 -0000
Hi Ron,
Diamond are using the Delta-Tau PMAC cards on the majority of the first
beamlines to be installed. If it is okay with you, Diamond is willing to
maintain and progress the PMAC device and driver support for the motor
record.
Cheers,
Martin
> -----Original Message-----
> From: Ronald L. Sluiter [mailto:[email protected]]
> Sent: 03 February 2005 15:23
> To: EPICS
> Subject: Re: DeltaTau PCI Motor Control Boards and Linux
> The latest motor record and device/driver support release is
> now available at;
> http://www.aps.anl.gov/upd/people/sluiter/epics/motor/index.html
> I caution potential users of the motor record Delta Tau PMAC
> device support on two counts.  First, the device support for
> the PMAC is a work in progress.  Second, since we here at the
> APS are not currently using the Delta Tau PMAC motor record
> device support, that work has to progress somewhere else besides APS.
> Ron Sluiter
Prev: PPT and PDF files of the presetation in EPICS meeting at TOKAI,JAPAN are now available on the web. Noboru Yamamoto
Next: RE: STATIC softIOC Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: DeltaTau PCI Motor Control Boards and Linux Ronald L. Sluiter
Next: Initial STAT and SEVR for soft ai and ao records Mark Rivers
