1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question about length of PV names
To: Gavin Smith <[email protected]>
Date: Mon, 07 Feb 2005 11:13:51 +0100
It depends.
The length of the records' name fields has been discussed a lot in the past - after some intermediate steps it has been raised for EPICS Base 3.14 to its current value of 61 bytes (which is 60 characters plus the NULL). (Any record's include file in <BASE>/include will have the definite answer in such cases - for any version of Base.)
Note that this is the limit of the EPICS IOC database record names. A PV name (e.g. for Channel Access) may be longer (else you wouldn't be able to address fields of a record with a 60 char name).
You are correct that other tools might have different limits. The chance of running against a hardcoded limit of 28 or 40 characters actually increases with the tool's age - EDM most probably being a safe choice. Luckily enough EPICS stuff is distributed as source code so you at least have a chance to fix things you don't like. ;-)
Good luck,
Ralph
Gavin Smith wrote:
Hello All,
What is the character limit on the length of PV names in EPICS? I have seen things referring to 28 chars, 40 chars and 60 chars. Whilst I have sucessfully made a record with a double alphabet name (i.e. 26x2=52 chars) I am wary that other programs (such as EDM) may have different limits.
Gavin Smith.
Re: Question about length of PV names Andy Foster
Question about length of PV names Gavin Smith
Prev: Question about length of PV names Gavin Smith
Next: Re: Question about length of PV names Andy Foster
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
