1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question about length of PV names
To: Andy Foster <[email protected]>
Cc: Gavin Smith <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Mon, 07 Feb 2005 13:22:04 +0100
Didn't want to cause confusion ... sorry!
The PV name length restrictions within Channel Access have been gone for quite a while. (Actually: years, I guess.) The only remaining limit is the UDP packet size. (Hope you never have to type _that_ name.)
Keep in mind that things are different for strings within Channel Access data - as these are bound to the predefined DBR_* types they are restricted to the DBR_* type and length limits.
Cheers,
Ralph
Andy Foster wrote:
Hi Ralph,
I'm confused now. I though the client tool limit for searching for
PV names was set by the maximum string length in Channel Access
i.e. 40 characters, which hasn't changed right?
So, when the maximum PV name length was 29 chars in base, since this was
less than 40, it was all OK. What happens now when you have a PV
name longer than 40 chars, does the CA search call just truncate
the name? Or have I completely misunderstood the way the search
name is passed over CA?
Cheers,
Andy
On Mon, 7 Feb 2005, Ralph Lange wrote:
It depends.
The length of the records' name fields has been discussed a lot in the
past - after some intermediate steps it has been raised for EPICS Base
3.14 to its current value of 61 bytes (which is 60 characters plus the
NULL). (Any record's include file in <BASE>/include will have the
definite answer in such cases - for any version of Base.)
Note that this is the limit of the EPICS IOC database record names. A PV
name (e.g. for Channel Access) may be longer (else you wouldn't be able
to address fields of a record with a 60 char name).
You are correct that other tools might have different limits. The chance
of running against a hardcoded limit of 28 or 40 characters actually
increases with the tool's age - EDM most probably being a safe choice.
Luckily enough EPICS stuff is distributed as source code so you at least
have a chance to fix things you don't like. ;-)
Good luck,
Ralph
Gavin Smith wrote:
Hello All,
What is the character limit on the length of PV names in EPICS? I have
seen things referring to 28 chars, 40 chars and 60 chars. Whilst I
have sucessfully made a record with a double alphabet name (i.e.
26x2=52 chars) I am wary that other programs (such as EDM) may have
different limits.
Gavin Smith.
Re: Question about length of PV names Andy Foster
Prev: Re: Question about length of PV names Andy Foster
Next: Re: Question about length of PV names Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
