Dirk,
I don't know if anyone has made this suggestion, but
watch out for a driver that uses floating point in its
interrupt service routines as, on vxWorks, the FP
register contents are not saved / restored when entering
/ exiting interrupt context. The driver must do this
manually if it finds a need to use FP in its ISR.
Jeff
> -----Original Message-----
> From: Dirk Zimoch [mailto:[email protected]]
> Sent: Tuesday, February 08, 2005 5:51 AM
> To: TECHTALK
> Subject: compiler bug in gcc version 2.8.1 (Tornado1)
> for PPC corrupts floationg point constants?
> Hi all,
> I have some driver software that contains
> double scan_period;
> scan_period = 0.05;
> The function is executed from startup script, i.e. the
> executing task is
> a floating point task.
> However, sometimes when booting R3.13.2, the ioc
> crashes with "floating
> point underflow" while executing
> printf ("init_record_generic: scan_period=%f\n",
> scan_period);
> I couldn't even look at the registers, because ti also
> crashes when it
> tries to print the register containing scan_period.
> According to the bitpattern, scan_period is not 0.05,
> but some
> denormalized value.
> Even more astonishing is that the error only happens
> sometimes! In rare
> cases, everything is OK. When I boot R3.13.5, also
> everything is OK. I
> have compared the driver library compiled for both
> EPICS versions. It is
> exactly the same object code.
> We load the driver library in the startup script.
> Maybe there is
> something wrong with the ld command, corrupting
> constants?
> But how can this depend on the EPICS release? Maybe
> the code is loaded
> to another location, but does the location matter?
> Why does this only happen with one driver?
> Any ideas or solutions?
> Dirk
> Dr. Dirk Zimoch
> Swiss Light Source
> Paul Scherrer Institut
> Computing and Controls
> phone +41 56 310 5182
> fax +41 56 310 4413
- Re: compiler bug in gcc version 2.8.1 (Tornado1) for PPC corrupts floationg point constants? Ralph Lange
- compiler bug in gcc version 2.8.1 (Tornado1) for PPC corrupts floationg point constants? Dirk Zimoch
Re: R3.14.7 next build error ?! Ralph Lange
<2005>
2025
2026
RE: compiler bug in gcc version 2.8.1 (Tornado1) for PPC corrupts floationg point constants? Lawrence T. Hoff
<2005>
2025
2026
