Hi EPICS gurus,
Maybe this is a question that has been asked previously, but I can't find
anything about it on tech-talk.
I am compiling a sequencer program as a standalone application using the
second of the two choices in the Makefile, e.g.
#The following builds sncExample as a standalone application
PROD_HOST += sncExample
sncExample_SNCFLAGS += +m
sncExample_SRCS += sncExample.stt
sncExample_LIBS += seq pv
sncExample_LIBS += $(EPICS_BASE_HOST_LIBS)
I am using RedHat Linux 9, Sequencer version 2.07 and EPICS 3.14.6.
The Sequencer Manual states in Section 4.2 "Unix Specific Instructions"
that after the program has been executed from the command line (by typing
"sncExample" in the above example) the console will remain active and a
number of sequencer commands (e.g. "all", "channels" etc) should become
available.
However, I have not been able to get the sequencer to respond to any
commands while it is running as a standalone application. In fact the
console is totally unresponsive and doesn't even respond to an <EOF> Ctrl-D
to exit from it. I am interested to know if there is something else I need
to do to gain access to the sequencer console, or is this functionality
which is just not available in Linux.
Steve Banks
The Australian Synchrotron (Big Round Building)
800 Blackburn Road
Clayton Vic 3168
tel: +613 8540 4103
fax: +613 8540 4200
web: www.synchrotron.vic.gov.au
Any personal or sensitive information contained in this email and
attachments must be handled in accordance with the Victorian Information
Privacy Act 2000, the Health Records Act 2001 or the Privacy Act 1988
(Commonwealth), as applicable.
This email, including all attachments, is confidential. If you are not the
intended recipient, you must not disclose, distribute, copy or use the
information contained in this email or attachments. Any confidentiality or
privilege is not waived or lost because this email has been sent to you in
error. If you have received it in error, please let us know by reply
email, delete it from your system and destroy any copies.
VxWorks 6.0 and EPICS R3.14.7 Ernest L. Williams Jr.
Fault-tolerance in EPICS Klemen Zagar
<2005>
2025
2026
<2005>
2025
2026
