1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fault-tolerance in EPICS common approach?
To: Klemen Zagar <[email protected]>, EPICS tech-talk <[email protected]>
Date: Tue, 22 Feb 2005 09:00:20 +0100
Hi Klemen,
fault tolerance and reliability are topics which will be also discussed for the next EPICS version-V4.
Within the time frame of the next three years we are planning to introduce redundant IOC's into the next EPICS version. In order to introduce the collected ideas of the team working on these subjects - rather than individual thoughts - it will be necessary to know your time frame for the survey.
I'll be happy to enter our current thoughts but I would prefer to enter them based on an on going feasibility study and the results of several EPICS meetings within the next months.
Please keep me informed. It seems we have a common ground here.
-Matthias
Klemen Zagar wrote:
Dear EPICS users,
Cosylab is working on a EU-funded project on "Dependable Distributed Systems" (DeDiSys -- http://www.dedisys.org). The goal of the project is to investigate and improve availability of distributed systems when faults are present (e.g., when the network is down or when nodes crash).
Since EPICS is an infrastructure for distributed systems, we are considering to apply the results of our research work to EPICS as well. In order to do that, we need input from those who use EPICS in production environments, such as yourselves.
We have prepared a general questionnaire that is expected to gauge requirements and expectations with regard to fault tolerant behavior. I kindly ask you too take a bit of your time and fill it in. It is conveniently available on the web:
http://www.xlab.si/dedisys/start.php
(It takes about 20 to 30 minutes to make it through all the questions. If you wish to be kept informed of the project's progress, you might also wish to sign-in for the interest group.)
Since questionnaire is very generic, we would also welcome any additional input specific to EPICS, such as:
1. How frequent are failures at your facility?
2. How many of the failures are critical in a sense that operations of the entire facility are disturbed (e.g., a beam dump)?
3. How many failures could be attributed to EPICS or the control system itself (e.g., network congestions, defects in software, erratic behavior of controls hardware, ...)?
4. How many of these failures could EPICS help to avoid, and in what way (redundancy, replication of records, reliability APIs for developers, guidelines for development of reliable systems, ...)?
5. What is the typical down-time as a sequence of a failure?
6. Could EPICS be improved to help reduce this down-time? If so, how (e.g., allow reconfiguration without IOC restart, ...)?
In order to reduce traffic on the mailing list, please answer directly to myself, and I will summarize your contributions in a later posting.
Thank you for your cooperation,
  Klemen Zagar.
-- ------------------------------------------------------------------------ Matthias Clausen Cryogenic Controls Group(MKS-2) phone: +49-40-8998-3256 Deutsches Elektronen Synchrotron fax: +49-40-8994-3256 Notkestr. 85 e-mail: [email protected] 22607 Hamburg WWW-MKS2.desy.de Germany ------------------------------------------------------------------------
Fault-tolerance in EPICS Klemen Zagar
Prev: Fault-tolerance in EPICS Klemen Zagar
Next: Flavors of Linux Gary P Carr
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
