1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Flavors of Linux
To: [email protected]
Date: Wed, 23 Feb 2005 16:16:37 -0500
I chose Red Hat Fedora Core 1 Linux.
Why?
The limitation that I faced with using Linux was SL-GMS. At the time, I began testing (two years ago) EPICS, SL-GMS software and Linux, only Red Hat version 7.3 was supported by SL-GMS. Today ???
FROM MY DEVELOPMENT NOTES:
"Tested Sherrill-Lubinski Graphical Modeling System (SL-GMS)
software under Redhat Linux 7.3, 8.0, and 9.0 and Fedora Linux Core 1.
Fedora Core 1 is the best choice because a remote X-terminal screen
sizing problem has been fixed. Only Fedora Linux Core 1 adjusts the
remote screen size to that of the remote X-terminal display.
Fedora Core 1 and RedHat Linux 7.3 allow the SL-GMS control window
to be moved and resized while using the GNOME or KDE desktop environments.
Redhat Linux 8.0 and 9.0 only allowed the SL-GMS window to be moved and resized under the KDE desktop environments.
The new Fedora Linux, which replaces RedHat Linux will be supported.
RedHat Linux will not be supported anymore."
Fedora Core 2 was released after, my development/testing work was terminated. So, I have not tested the facility EPICS code under Core 2 and newer releases.
Fedora Core 1 represents the last of the 2.4.x kernel.
Fedora Core 2 represents the first of the 2.6.x kernel.
Usually the last of a series is the best OS while the first of a series has the most problems.
Billy Adams <mailto:[email protected]> NASA/Langley ROME Group Assigned to: Center Operations Directorate NASA Langley Research Center Hampton, Va. 23681-2199 Phone 1-757-224-7858 Fax 1-757-224-7870
Prev: Re: Flavors of Linux Maren Purves
Next: RTEMS-4.7 for uCDIMM module. Kiman Ha
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Data Access Class Library Tutorial Jeff Hill
