Benjamin Franksen wrote:
On Wednesday 16 February 2005 20:42, Marty Kraimer wrote:
If all that is desired to to make the record not be in alarm after
initialization then just set
field(SEVR,"NO_ALARM")
field(STAT,"NO_ALARM")
field(UDF,"0")
In the record instance definition.
Note that you can leave out SEVR and STAT as these are the default
values anyway.
However, at least with 3.13.9 this doesn't work. The record (a bo) is
still UDF/INVALID after booting.
Ben
In both 3.13 and 3.14 dbCommon.dbd has the definitions:
field(STAT,DBF_MENU) {
prompt("Alarm Status")
special(SPC_NOMOD)
menu(menuAlarmStat)
initial("UDF")
field(SEVR,DBF_MENU) {
prompt("Alarm Severity")
special(SPC_NOMOD)
menu(menuAlarmSevr)
initial("INVALID")
Thus the defaults are STAT=UDF and SEVR=INVALID.
- Re: Initial STAT and SEVR for soft ai and ao records Benjamin Franksen
- RE: Initial STAT and SEVR for soft ai and ao records Mark Rivers
- Re: Initial STAT and SEVR for soft ai and ao records Marty Kraimer
Re: Epics research - RDBMS support for Epics Trivan Pal
<2005>
2025
2026
<2005>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
