1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dm and edm problems with CA gateway
To: Rolf Keitel <[email protected]>
Cc: tech_talk <[email protected]>
Date: Fri, 04 Mar 2005 23:34:05 +0100
Hi Rolf,
we have seen the same problems with the V2.0 Gateway running on Linux. I was able to cut it down to a small Linux system with just one analog record running on a soft IOC and a Gateway running on the same machine exporting this channel on a different port number. Starting camonitor on a different host to directly watch the channel on the IOC I was able to see random junk values being written into the channel as soon as two clients are writing fast (slider) through the Gateway. Not just jumps (that I'd expect), but really random bit patterns that are interpreted as doubles. No matter which system the clients run on (tested with HP and Linux). Connecting the clients directly to the soft IOC - no problem.
At BESSY it didn't kill hardware as our DRVHs are set properly ... I hope. We lost the beam a couple of times until - as an instant measure - we stopped running write accesses through the Gateway. Read accesses seem to work fine.
The V1 Gateway does not show this behaviour - but we had to switch to V2 because the old hardware died.
I was already reporting this problem some months ago, but the APS installation hardly uses write access through the Gateway (if at all), so Ken doesn't see these problems - which makes it hard finding the bugs as well as the motivation to fix them. But again: One Linux box running one ao channel on a soft IOC, the Gateway, the camonitor, and two simple clients is enough to reproduce the problem. (On my RH8 Linux box, at least.)
Hope this helps (well, I know it doesn't really, but ...;-)
Ralph
Rolf Keitel wrote:
**** Has anybody else experienced these problems? ****
When we are operating sliders to write process variables through the CA gateway, every now and then on releasing the sliders the gateway writes huge (and I mean r e a l l y huge positive or negative) numbers to the IOC, which set the PV to the upper or lower end of the allowed range.
This never happens if you don't use the gateway.
We observed this behaviour both with dm and with edm (running on Solaris or Linux Redhat 9).
The gateway is running on a Linux (Redhat 9) box. Several gateway releases up to Beta18 (built against EPICS R3.14.6) exhibit this behaviour.
We lost a couple of devices, where a user hadn't specified a proper DRVH for the setpoint.
We have taken the gateway out of operation until this is resolved.
- rolf -
RE: dm and edm problems with CA gateway Jeff Hill
dm and edm problems with CA gateway Rolf Keitel
Prev: Re: dm and edm problems with CA gateway Kenneth Evans, Jr.
Next: Re: dm and edm problems with CA gateway Rolf Keitel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: dm and edm problems with CA gateway Rolf Keitel
Next: RE: dm and edm problems with CA gateway Jeff Hill
