1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: re: about Tektronix TDS3000 series oscilloscopesdevice device support
Date: Tue, 8 Mar 2005 17:30:49 +0800
tech-talk,hi
Dear Kim, Kukhee
   Thank you for help!
   on the "EPICS" homepage http://www.aps.anl.gov/epics/modules/instrument/tds3000/index.html , I downloaded
   the software(tds3000_R1-1.tar.gz) from the link. the following is the installation instructions on the page:
Installation
After obtaining a copy of the distribution, it must be installed and built for use at your site.
  • Create an installation directory for the module, usually this will end with modules/instrument/tds3000
  • Unpack the distribution tar file in the installation directory. The software appears in a subdirectory named after the release number. cd to this subdirectory.
  • Edit the configure/RELEASE file and set the path to your installation of EPICS base.
  • Run gnumake in the top level directory
After installing the tds3000 device support, download and install the Asyn Driver Support which the tds3000 needs. This can be found here. Install the latest version.
I followed every step in the instructions. But I met that error when I ran gnumake. I don't know why.
Attachment: pikaqu.gif
Description: GIF image
RE: about Tektronix TDS3000 series oscilloscopesdevice device support Kim, Kukhee
Prev: Re: Who is using what EPICS version Dirk Zimoch
Next: RE: about Tektronix TDS3000 series oscilloscopesdevice device support Kim, Kukhee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: about Tektronix TDS3000 series oscilloscopesdevice device support Kim, Kukhee
