1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: calcout ODLY field
To: [email protected]
Date: Fri, 1 Apr 2005 01:30:11 +0200
On Friday 01 April 2005 01:18, Geoff Savage wrote:
> I'm trying to delay the output of a calcout record using EPICS 3.14.6,
> vxworks 5.5.1.  When I set the ODLY field to 1.0 there does not appear
> to be any delay.  When I set the ODLY field to 10.0 I get this message
> on the console - "callbackRequest called with invalid priority".  Would
> someone please be kind enough to send me an example?
Hi Geoff,
this sounds very much like your calcout record's header and dbd files don't
match. Maybe you are using record support from a different release than your
dbd is from? Some string fields of the calcout record have changed their
sizes somewhere between R3.14.2 and R3.14.6.
Ben
calcout ODLY field Geoff Savage
Prev: calcout ODLY field Geoff Savage
Next: steppermotor vs. motor record compatibility John Spring
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: calcout ODLY field Gasper Jansa
