1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA for IOCs w/ dual NICs
To: Kate Feng <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 15 Apr 2005 13:43:55 -0400
Hi Kate,
Please provide more info.
For example, maybe your default route was being provided by the network
you disconnected.  Try the same experiment but disconnect the other
cable.  Does the same thing happen?
Send the output of your routing table:
routeShow
Ernest L. Williams Jr.
SNS Control Systems Group
ORNL
On Fri, 2005-04-15 at 13:27 -0400, Kate Feng wrote:
> Hi,
> There are two network interfaces (N.I.) on my IOC, each attached
> to  a  different  IP address. I  thought one could  decide which medm
> clients  "Channel Accessing"  which  N.I. by opening two windows.
> Both windows  are set with  EPICS_CA_AUTO_ADDR_LIST = NO.
> Window #1 is set with EPICS_CA_ADDR_LIST= IP1, while
> window #2  is set with  EPICS_CA_ADDR_LIST= IP2.
> Is ther any other better way ?   I wanted to make sure  that certain
> clients  CA the specified IP, instead of  the other one.  Thus, I
> disconnected
> one of the cable going to that specified N.I.  However, when I do that,
> all the medm clients on both windows  became disconnected from the IOC.
> Any pointer highly appreciated,
> Kate
CA for IOCs w/ dual NICs Kate Feng
Prev: CA for IOCs w/ dual NICs Kate Feng
Next: RE: CA for IOCs w/ dual NICs Liyu, Andrei
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: CA for IOCs w/ dual NICs Andrew Johnson
