1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: semTake failure within ca functions
To: "'[email protected]'" <[email protected]>
Date: Thu, 28 Apr 2005 13:44:20 -1000
Aloha
We have two systems that are suffering from occasional semTake failures
within iocinf.c.  Said systems are running an ancient version of EPICS but
there appear to be only minor differences between it and R3.13.8, in this
respect.
I suspect that this is a timing/synchronization issue, whereby the ca_static
structure is deleted in one task (cac_add_task_variable within
vxWorks_depen.c) whilst another task is using a semaphore within that
structure (cac_clean_iiu_list within iocinf.c), prior to the the first task
obtaining it's task local copy.
Is anyone cognizant of a 'patch' to rectify this problem?
Or, if I am way off base, does anyone have the correct solution?
seqAux: A call to "assert (semTake(client_lock, WAIT_FOREVER)==OK)" failed
in ../iocinf.c at 1046
Sat Apr 23 00:22:15 2005 Please send a copy of the output from "tt
(0x352a320)" and a copy of this message to the author or
"[email protected]"
Sat Apr 23 00:22:15 2005 This problem occurred in "@(#)Version
R3.13.0.beta.12 $$ Date: 1998/08/18 02:02:32 $$"
Sat Apr 23 00:22:17 2005 filename="../taskwd.c" line number=175
Sat Apr 23 00:22:17 2005 task 352a320 seqAux suspended
thanks for any help you can provide
	Allan
RE: semTake failure within ca functions Jeff Hill
Prev: RE: SNL suffix and preprocessing Redman, Russell O.
Next: RE: semTake failure within ca functions Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: bad UDP msg wtw00992
