1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EDD on KDE
To: [email protected]
Date: Fri, 06 May 2005 22:30:21 -0700
Now I find the following: while dm works just fine on KDE, edd doesn't,
or at least copying and pasting doesn't, but gives me a clipboard error.
The solution to this is to switch back to gnome (where I knew this
> worked before, and it still works now) just for the editing, which I did
from a different machine to save me the logging out and running
everything else back up.
(the parts of edd that do work on KDE require double mouse clicks)
Aloha,
Maren
I use KDE as a desktop, and even though my Linux box is not hosting EDD/DM, the clipboard still messes it up. I found that closing the lttle clipboard (klipper?) down in the corner of the screen fixed things up. Drove me crazy for the longest time.
Rod Nussbaumer
TRIUMF
Re: EDD on KDE Maren Purves
Prev: edd doesn't work on WBEL4 with KDE (but does with gnome) Maren Purves
Next: Re: EDD on KDE Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
