1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: excessive ioc memory utilization
To: Jeff Hill <[email protected]>
Cc: "'EPICS Tech-Talk'" <[email protected]>
Date: Tue, 10 May 2005 15:13:06 -0500
Hi Jeff,
The culprit was a misbehaving channel access client. Somehow it connected tens of thousands of channels which increased the memory usage by CA. When it was stopped the memory on the IOC was not returned. Are there tools to monitor the CA memory usage? Is this the expected behaviour of CA?
Thanks, Geoff
Jeff Hill wrote:
Geoff,
Use memShow to obtain status of the system pool. A common cause
of system pool depletion will be system pool data structure
corruption, or of course some program continuously allocating
memory that it does not free. The former shows up instantaneously
while the latter generally can be predicted as a trend. If the
problem is easily reproducible you may find that selective use of
the task suspend command can be used to isolate the responsible
thread. Typically a binary search is used where you suspend one
half of the threads initially followed by half of the remaining
half etc to tighten the noose with minimized effort.
With your version of vxWorks the network stack pool shouldn't be
increasing past the limits set when vxWorks is built.
There is an integer level argument to casr that can be used to
get more information about what it has allocated.
Jeff
-----Original Message-----
Sent: Tuesday, May 10, 2005 9:48 AM
To: EPICS Tech-Talk
Subject: excessive ioc memory utilization
When I came in this morning our high voltage iocs are using
excessive
amounts of memory, around 95%.  They are all mv2301 processors
with 16MB
of memory running epics 3.14.6 built with vxworks 5.5.1.  The
netStackSysPoolShow and netStackDataPoolShow outputs are
reasonable.
There are not an excessive number of channels connected.  What
can I use
to look and see where the memory is allocated?  Any other
suggestions?
Thanks, Geoff
-> netStackSysPoolShow
type        number
FREE    :    5991
DATA    :      0
HEADER  :      0
SOCKET  :     21
PCB     :     35
RTABLE  :     91
HTABLE  :      0
ATABLE  :      0
SONAME  :      0
ZOMBIE  :      0
SOOPTS  :      0
FTABLE  :      0
RIGHTS  :      0
IFADDR  :      4
CONTROL :      0
OOBDATA :      0
IPMOPTS :      0
IPMADDR :      2
IFMADDR :      0
MRTABLE :      0
TOTAL   :    6144
number of mbufs: 6144
number of times failed to find space: 0
number of times waited for space: 0
number of times drained protocols for space: 0
__________________
CLUSTER POOL TABLE
_______________________________________________________________
________________
size     clusters  free      usage
64       1024      965       15123
128      1024      996       1647
256      512       446       10893
512      512       512       0
value = 80 = 0x50 = 'P'
type        number
FREE    :    5991
DATA    :      0
HEADER  :      0
SOCKET  :     21
PCB     :     35
RTABLE  :     91
HTABLE  :      0
ATABLE  :      0
SONAME  :      0
ZOMBIE  :      0
SOOPTS  :      0
FTABLE  :      0
RIGHTS  :      0
IFADDR  :      4
CONTROL :      0
OOBDATA :      0
IPMOPTS :      0
IPMADDR :      2
IFMADDR :      0
MRTABLE :      0
TOTAL   :    6144
__________________
CLUSTER POOL TABLE
________________
64       1024      965       15125
128      1024      996       1647
256      512       446       10894
512      512       512       0
-> casr
Channel Access Server V4.11
Connected circuits:
TCP 131.225.231.65:46261(d0olj.fnal.gov): User="d0cal", V4.8,
70
Channels, Priority=0
TCP 131.225.230.156:1026(d0olctl38): User="vxworks", V4.11, 6
Channels,
Priority=80
TCP 131.225.231.39:45142(d0ol57.fnal.gov): User="d0fpd", V4.8,
6
TCP 131.225.231.39:45149(d0ol57.fnal.gov): User="d0fpd", V4.8,
4
TCP 131.225.231.252:60499(d0ol49.fnal.gov): User="d0fpd", V4.8,
4
TCP 131.225.231.252:49088(d0ol49.fnal.gov): User="d0fpd", V4.8,
30
TCP 131.225.231.39:49714(d0ol57.fnal.gov): User="d0fpd", V4.8,
6
TCP 131.225.231.247:42004(d0ol45.fnal.gov): User="d0cal", V4.8,
3
TCP 131.225.231.247:43286(d0ol45.fnal.gov): User="d0cal", V4.8,
128
value = 0 = 0x0
RE: excessive ioc memory utilization Jeff Hill
Prev: RE: excessive ioc memory utilization Jeff Hill
Next: RE: excessive ioc memory utilization Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
