1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Porting db file generation from 3.13 to 3.14
To: <[email protected]>
Date: Wed, 8 Jun 2005 17:09:34 +0100
I've just started using EPICS 3.14.6 and encountered the same problem as
Benjamin Franksen from Bessy (original tech-talk posting follows this
email).
At Diamond we use the same approach i.e. produce an expanded db file
using a substitution file and an (externally defined) template file. In
R3.13.x we used to do this by having the following lines in the
Makefile.Host file of the /Db directory:-
DB +=  test.db
USES_TEMPLATE += $(TEMPLATE_PATH)/test.template
This didn't seem to work in EPICS 3.14.6, due to an error in the
RULES.Db file. The following corrects this problem:-
--- RULES_Db.ori        2005-06-08 17:02:07.000000000 +0100
+++ RULES.Db    2005-06-08 17:02:37.000000000 +0100
@@ -138,5 +138,5 @@
 TEMPLATE_LINKS = $(filter-out $(notdir $(USES_TEMPLATE)),
$(USES_TEMPLATE))
 TEMPLATE_FILES = $(filter     $(notdir $(USES_TEMPLATE)),
$(USES_TEMPLATE))
-COMMON_TEMPLATES=$(addsuffix $(COMMON_DIR)/,$(notdir
$(TEMPLATE_LINKS)))
+COMMON_TEMPLATES=$(addprefix $(COMMON_DIR)/,$(notdir
$(TEMPLATE_LINKS)))
Cheers,
Martin Norbury
Software Engineer Beamline Systems
Diamond Light Source Ltd.
Rutherford Appleton Laboratory
Chilton, Didcot.
Oxon
OX11 0QX
Tel: 44 (0) 1235 778235
Email: [email protected]
> -----Original Message-----
> I'm in the early stages of porting a 3.13 application to 3.14 and got
> stuck almost immediately.
> Our typical application creates X.db using X.substitutions
> and template
> files a.template and b.template. X.substitutions looks like this
> file a.template {
>   { NAME="a1" }
>   { NAME="a2" }
> file b.template {
>   { NAME="b1" }
>   { NAME="b2" }
>   { NAME="b3" }
> In my old (3.13) Makefile.Host I have
> USES_TEMPLATE = a.template b.template
> DB = X.db
> which creates X.db by calling (more or less)
> msi -S X.substitutions > X.db
> That is, msi is used as substitution for host side dbLoadTemplate.
> What definitions do I need in my Makefile to make this work in 3.14?
> Make complains about a missing "../X.template".
> I read chapter 4 of the ADG but there is no clue to what I should do
> here. The doc seems to suggest that expanding substitutions files in
> the dbLoadTemplate style is no longer supported because it seems that
> *one* template file is required for each substitution file
> and a subst
> files like the above obviously needs not one but many different
> template files.
> Almost all of our applications use above style to expand db
> on the host
> side and most of the substitutions files are generated by
> scripts from
> a relational Database.
> I am quite astonished that I seem to be the first one stumbling over
> this. Any suggestion on how to proceed would be greatly appreciated.
> Ben
Re: Porting db file generation from 3.13 to 3.14 Janet Anderson
Prev: Re: SSCAN parameters problem Tim Mooney
Next: Re: epics on ecos Ronald L. Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Porting db file generation from 3.13 to 3.14 Janet Anderson
