before we upgrade SSCAN record (or SynApps?) let me please ask 2 questions: We are using SSCAN record version 5.12 together with saveData (synApps release 1.4 Jan2004) on EPICS 3.13.2 1) I observed that changing the STEP SIZE (or WIDTH?) to a negative value (you know the users do all kind of strange things) lead to the crash of the saveData task on the ioc. 2) When I put as an detector an array-valued PV, also confirmed by SSCAN message window, the saveData saves only zeros. The same happens if we specify GET-ARRAYS in the ACQ MODE for the detectors. I'd be glad at the end to save 2D scans with array-valued PVs which I believe would be a perfect solution for the mXAS beamline. -- _____ Swiss / / [email protected] _/_/_/ _/ _/_/_/ /____ Beamline Controls Group _/ _/ _/ Source / Paul Scherrer Institute _/_/ _/ _/_/ ____/ CH-5232 Villigen-PSI _/_/Light _/ / Tel: ++41 56 310 5131 _/_/_/_/_/_/_/ _/_/_/___/ Fax: ++41 56 310 3151
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
