1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Invisible genSub record
To: Brian McAllister <[email protected]>
Cc: [email protected]
Date: Fri, 10 Jun 2005 11:20:47 -0700
Brian McAllister wrote:
On 6/9/2005 at 16:08:36 PDT, Eric Williams wrote:
> I'm trying to use genSub record v1-6 I found in synApps 5-1 under EPICS > 3.14.7 on a linux-x86 machine. The record is getting processed and my > init and process routines are getting called correctly, but the record > does not appear in the list of records produced by dbl. Trying to > access it by name results in a dbNameToAddr failure. Anybody want to > hazard a guess what's gone wrong?
Based on similar problems I've encountered in the past, one possibility is
that the NAME field is being overwritten or corrupted by code which is
trying to write to some other field in the record using an incorrect
offset/pointer, or is overflowing a field in the record preceding this one
in memory (NAME is the first field in a record).
Look carefully in the dbl output for a record name which you don't
recognize or is truncated or otherwise corrupted.
You could also try loading your databases in a different order and see if
the problem moves or changes.
No mystery records appear in the dbl list, and re-ordering the database load doesn't seem to have had any effect. Are there some debugging flags that can be turned on for the dbLoadRecords call to see what is going on?
Re: Invisible genSub record Brian McAllister
Prev: Linux host problems Peregrine McGehee
Next: Re: LabVIEW RT interface with EPICS Willem Blokland
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Invisible genSub record Brian McAllister
Next: Open source Real-time Oss / open source OS Dalesio, Leo `Bob`
