1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: cygwin-x86
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 15 Jun 2005 10:01:19 -0500
When building for cygwin-x86 I ran into two errors, semi-colons that were not expected by the compiler. I built epics in the 3.14.7 directory and compared it to base-3.14.7 which is right out of the distribution file.
diff -r 3.14.7/src/libCom/osi/epicsThread.cpp base-3.14.7/src/libCom/osi/epicsTh
read.cpp
32c32
< void epicsThreadRunable::show ( unsigned int ) const {}
> void epicsThreadRunable::show ( unsigned int ) const {};
Only in 3.14.7/src/libCom/test: O.cygwin-x86
diff -r 3.14.7/src/libCom/test/epicsListTest.cpp base-3.14.7/src/libCom/test/epi
csListTest.cpp
192c192
I installed cygwin, epics base v3.14.7, set EPICS_HOST_ARCH to cygwin-x86, and did a gmake cygwin-x86. Any suggestions?
Thanks, Geoff
Prev: problem during "make" Chithra Karunakaran
Next: RE: cygwin-x86 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: problem during "make" Maren Purves
