1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Symbolic device support for the Linux OS
To: [email protected]
Date: Thu, 30 Jun 2005 12:29:58 -0500
J. Frederick Bartlett wrote:
Has anyone implemented EPICS symbolic device support under the Linux OS for v3.14? If not, does anyone have any good ideas about a possible implementation, e.g. shared memory?
What do you need it to do?
If you just want something very similar to the vxWorks support you might be able to hack something derived from the vxWorks code that uses the linux dlopen(NULL, ...) and dlsym() routines.
I did spend some time last year trying to update the vxWorks code while thinking about updating it to be used for any OS (requiring all variables to be registered in the DBD file using variable() statements) but I got side-tracked and gave up.
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
Symbolic device support for the Linux OS J. Frederick Bartlett
Prev: Re: device support for SNMP Janet Anderson
Next: Re: sourcing MVME cpu boards Steven Hartman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Symbolic device support for the Linux OS J. Frederick Bartlett
Next: sourcing MVME cpu boards Ian A Smith
