1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: odd libca message printed
To: <[email protected]>
Cc: "self" <[email protected]>
Date: Fri, 1 Jul 2005 12:38:09 -0400
I have downloaded EPICS base 3.14.7 and built it under the provided 'hpux-parisc' setting of $EPICS_HOST_ARC. All built fine. I built a test client program that performs a couple channel access fetches and prints the results. The test program works fine when I build against our existing EPICS 3.13.2 installation, but there is a problem running with the newer EPICS version. The program performs the channels access operations correctly, but the signal value prints are sometimes followed by "epicsThreadOnceOsd epicsMutexLock failed" written to the command shell. I suspect the message is generated when I close the channel and exit the program. The number of times the message is written varies from zero to two. More often it is zero, and only once have I seen two. Can anyone explain to me what this message means, and what I need to do to correct it?
          Chris Slominski
Thomas Jefferson National Accelerator Facility
Phone:(757) 269-6030 Pager: 584-6030
RE: odd libca message printed Jeff Hill
Prev: Unbounded integer types Benjamin Franksen
Next: vmivme7050 Ian A Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: odd libca message printed Jeff Hill
