1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: UDP send, errno=0x37
To: "'Geoff Savage'" <[email protected]>, "'EPICS Tech-Talk'" <[email protected]>
Date: Tue, 5 Jul 2005 09:48:50 -0600
Geoff,
> Over the weekend we received these error messages from an mv5500 running
> vxworks 5.5 and epics 3.14.6.  As far as I can tell this is an ENOBUFS
> error.  Is this the correct interpretation?
Yes, that is the ENOBUFS error number. The default error number to string
converter uses strerror(), and on your build of vxWorks strerror() returns
the string "errno = 0x37".
> What buffer needs to overflow to get this error?
The ENOBUFS error number is a catch all for any pool exhaustion problems in
the IP kernel. With newer versions of vxWorks the size of the IP stack's
buffer pool is fixed at compile time. See the debugging section of the CA
reference manual.
> I thought the only UDP
> messages from an IOC were beacons to port 5065.  What are the other UDP
> messages to ports other than 5065?  Could this indicate a problem
> somewhere else on our network?
The CA server is sending a search response message to address
"131.225.231.247:35139". Presumably you have a CA client whose ephemeral UDP
port assignment on 131.225.231.247 is 35139.
> Could this indicate a problem somewhere else on our network?
If your network stack pool has a standard out-of-the-box configuration then
the most likely cause is local (pool allocation configuration that does not
match up with the load).
You might also consider running casw in order to track you beacon anomaly
rates. Beacon anomalies can be used to identify IOCs with weak network
connections.
Jeff
> -----Original Message-----
> From: Geoff Savage [mailto:[email protected]]
> Sent: Tuesday, July 05, 2005 8:29 AM
> To: EPICS Tech-Talk
> Subject: UDP send, errno=0x37
> Hi,
> CAS: UDP send to "131.225.231.247:35139" failed because "errno = 0x37"
> ../online_notify.c: CA beacon (send to "131.225.231.255:5065") error was
> "errno
> = 0x37"
> CAS: UDP send to "131.225.231.65:33655" failed because "errno = 0x37"
> What buffer needs to overflow to get this error?  I thought the only UDP
> Thanks, Geoff
UDP send, errno=0x37 Geoff Savage
Prev: RE: UDP send, errno=0x37 Allison, Stephanie
Next: RE: odd libca message printed Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: UDP send, errno=0x37 Geoff Savage
Next: RE: UDP send, errno=0x37 Allison, Stephanie
