> Finally, I discovered that the
> network port for the CPU somehow got reconfigured to 100/full (long
story).
> Going to 100/half solved the problem. Hopefully, your problem will be
> solved by just increasing buffers.
As I recall, if the vxWorks IOC powers up when the switch is off it sets
full/half duplex to a default value, and appears to not re-auto-negotiate
full/half duplex again when the switch *is* powered up. The switch and the
IOC can end up inconsistent, and soft reboots do not help. Resetting the IOC
after the switch powers on appears to be the only solution.
Very low throughput communication is allowed to proceed when the
configuration of full/half duplex is inconsistent. This can cause increased
pool consumption in the IOC's IP kernel due to backlog for messages pending
transmit. Use of casw has been useful when detecting these problems.
Jeff
> -----Original Message-----
> From: Allison, Stephanie [mailto:[email protected]]
> Sent: Tuesday, July 05, 2005 9:47 AM
> To: Geoff Savage; EPICS Tech-Talk
> Subject: RE: UDP send, errno=0x37
> Hi Geoff,
> > Over the weekend we received these error messages from an
> > mv5500 running vxworks 5.5 and epics 3.14.6. As far as I can
> > tell this is an ENOBUFS error. Is this the correct interpretation?
> Yes. Looking at target/h/errno.h in my vxWorks distribution, I see that
> 0x37 (55) is ENOBUFS. I got similar messages on my vxWorks 5.4.2 target
> earlier this year. I tried increasing buffers... I tried John Sinclair's
> vxworks patch that he provided here...:
> http://www.aps.anl.gov/epics/tech-talk/2004/msg00221.php
> I swapped CPU boards... Nothing worked. Finally, I discovered that the
story).
> Stephanie Allison
- RE: UDP send, errno=0x37 Allison, Stephanie
RE: Asyn driver for FLUKE 8508A Mark Rivers
RE: EPICS 3.14.7 static client build Jeff Hill
<2005>
2025
2026
EPICS 3.14.7 static client build Chris Slominski
<2005>
2025
2026
