Subject: |
Re: ca gateway configuration for subnets |
Dayle Kotturi <[email protected]> |
To: |
"'EPICS Tech-Talk'" <[email protected]> |
Date: |
Thu, 14 Jul 2005 12:29:50 -0700 (PDT) |
Hi Chris,
I have some experience with this. A single host with dual-NICs needed to
act as a CA gateway server in two directions. In order to prevent the
ambiguity you suggest, it was necessary to explicitly lists the sources of
PVs (since there is no way to mask out an IP addr) for each CA gateway
process AND to make sure the CA gateway process ran as the correct IP
(that's the -sip arg or the EPICS_CAS_INTF_ADDR_LIST env var). Note that
wildcards wouldn't work in my case, since if I used them, I'd be including
the server and creating ambiguity.
HTH,
Dayle Kotturi [email protected]
LINAC Coherent Light Source
Stanford Linear Accelerator Center
On Thu, 14 Jul 2005, Maren Purves wrote:
> Paul Sichta wrote:
> > Chris,
> > I recall -sip and -cip args on the gateway's command line, to specify
> > the servers and client addresses. I guess a wildcard * would be
> > permitted in the IP specification.
> not having used it (so I'm guessing), if * doesn't work, I'd try a net
> mask.
> Maren
- Re: ca gateway configuration for subnets Ralph Lange
- ca gateway configuration for subnets Chris Timossi
- Re: ca gateway configuration for subnets Paul Sichta
- Re: ca gateway configuration for subnets Maren Purves
<2005>
2025
2026
<2005>
2025
2026
