Give this a try:
Before you start medm (or any CA client) set the EPICS_CA_ADDR_LIST like
so:
export EPICS_CA_ADDR_LIST="<linux-ip-number>:5064 <linux-ip-
number>:5066"
So, bascially the EPICS CA address list can contain a list of space
delimited entries in <IP>:portnumber format.
Ernest L. Williams Jr.
SNS Control Systems Group
ORNL
On Wed, 2005-07-27 at 19:29 -0700, Emmanuel Mayssat wrote:
> Hello all,
> I have 2 epics processes (ioc) running on the same linux computer at 2
> different ports.
> Now, I would like to use 1 top medm display to access the process
> variables of both processes.
> Accessing the PV of one of the iocs is easy.
> export EPICS_CA_SERVER_PORT=5064
> export EPICS_CA_REPEATER_PORT=5065
> medm -x <myMedmDisplay1>.adl
> and
> export EPICS_CA_SERVER_PORT=5066
> export EPICS_CA_REPEATER_PORT=5067
> medm -x <myMedmDisplay2>.adl
> Now if I create a <topDisplay>.adl that consists only of a [related
> display] medm widget that is referencing <myMedmdisplay1>.adl and
> <myMedmDisplay2>.adl, then it does not work.
> I can only access half of the process variables. That is the PVs of
> either the ioc running on port 5064 or 5066.
> How can I contact both ports at once?
> E
- medm and epics ports Emmanuel Mayssat
Making an ioc on linux go much faster Emmanuel Mayssat
problem when running epics ioc in win32 system 刘姝
<2005>
2025
2026
<2005>
2025
2026
