1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Changes to mv162 BSP in Tornado?
To: Peregrine McGehee <[email protected]>
Cc: [email protected]
Date: Thu, 28 Jul 2005 15:18:39 -0500
Peregrine McGehee wrote:
I have an IP module driver that sets the slot memory base
to 0x7200000 on an MVME-162 (Petra). We are upgrading from
vxWorks 5.1.1 to vxWorks 5.5 (T2.2) and attempts to access
this address now result in an access violation.
I've checked the target/mv162/config.h files - the treatment
of memory seems the same. Suggestions?
Have a look at your old target/mv162/sysLib.c file, in particular the sysPhysMemDesc[] array, which defines the areas of virtual memory that get mapped to physical memory - if an address is not covered here, the MMU will reject it immediately. You probably have an entry in the old table for the IP memory base address which you need to copy into the new version.
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
Changes to mv162 BSP in Tornado? Peregrine McGehee
Prev: Changes to mv162 BSP in Tornado? Peregrine McGehee
Next: help for error:can't locate program entry point_callocMustSucceed@12 to dynamic link library Com.dll Liu Shu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
