1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA Errors, but everything works fine !!!
To: [email protected]
Date: Sat, 06 Aug 2005 14:04:40 -0700
Hello,
When I start my IOC, everything works fine.
Nevertheless, I get the following error/warning messages:
CAS: Request from 192.168.1.202:33453 => cmmd=13 cid=0x32a type=11
count=5080 postsize=0
CAS: Request from 192.168.1.202:33453 =>  available=0xc0a801ca  N=0
paddr=0x87b7970
CAS: invalid (damaged?) UDP request from 192.168.1.202:33453 ?
CAS: request from 192.168.1.201:32836 => "invalid (damaged?) request
code from UDP"
CAS: Request from 192.168.1.201:32836 => cmmd=13 cid=0x45f type=11
count=5074 postsize=0
CAS: Request from 192.168.1.201:32836 =>  available=0xc0a801c9  N=0
paddr=0x87dbf64
CAS: invalid (damaged?) UDP request from 192.168.1.201:32836 ?
CAS: request from 192.168.1.201:32837 => "invalid (damaged?) request
code from UDP"
CAS: Request from 192.168.1.201:32837 => cmmd=13 cid=0x45f type=11
count=5072 postsize=0
CAS: Request from 192.168.1.201:32837 =>  available=0xc0a801c9  N=0
paddr=0x87dbf64
CAS: invalid (damaged?) UDP request from 192.168.1.201:32837 ?
Any idea of what is going on ?
Emmanuel
RE: CA Errors, but everything works fine !!! Jeff Hill
Prev: Re: logging activity of the epics PV Emmanuel Mayssat
Next: RE: CA Errors, but everything works fine !!! Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
